13 | |
11 | |
3 | |
3 | |
3 |
Languages like 'R', 'Python', and MatLab (yes I use the old name) have these. They are useful.
One of the key ideas in LabVIEW is that the user needs minimal interventions to code a useful result. As more information is encoded in a data type there is more opportunity to make "hands free" code that "just works". I think these two data types can do that.
Data Frame:
There are functions that data analysis folks do every day that are informed by variable type, so the function operating on the inputs doesn't need type specified because it is interior to the table. This means you can say "plot(mydata)" and if your data is set up well, the graph parameters are already specified and useful.
Some references:
Data table:
This is from Hadley Wickham, a very famous person in 'R'. He does great work, and his name has high brand value in data-analysis.
It:
In many applications the same operation is not possible due to memory constraint or viable due to processor overhead can execute adequately (aka wonderfully) by using this data type on the same hardware.
References:
