If the VI is called by something else in memory, disallow deletion; tell the user to unload the VI from memory first or gray out the delete option.
Ask the user to save callees similar to close from the menu.
The VI file should be moved to the recycle bin or the trash can depending on the OS.
Delete the file from any open referencing projects
