6 | |
2 | |
2 | |
1 | |
1 |
When you need to wait during the execution of a program, there is no elegant way to insert the wait vi in the dataflow. The only option is to add a one frame sequence structure.
With an error wire passing thru, the control of the dataflow is easier:
the dimmed error wire on the icon specify that the error is not being dealt with.
