When you compare two Vis, one with a control, and the other one with the same control but with a change on the test justification (You can modify it by clicking on the dropdown menu of text settings, next to the pause button)
If you compare the vis at this moment it only shows this
Difference Type: text justification
As we can see there is missing information regarding other comparissons like label name, object type and detailed description like the following example
Label Name: Label1
Object Type: String
Difference Type: moved
Detailed Description: Changed from "(168,132)" to "(12,71)"
Consider that this is a small scenario (only comparing two indicators) where the difference can be found easily, but if you try this with bigger VIs it will have a lot of missing information
The fact that this information is not available is time consuming, eventhough they can be walked manually the record of changes is compromised
