If the VI terminal is having 'Find Control' option lie Add Terminal, Remove Terminal then it would be easy to find the Controls which is located in the front panel.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Connector-pane-double-click-terminal-jumps-to-control/...
