13 | |
11 | |
3 | |
3 | |
2 |
I want class modifications to be saved immediately. It's very rare that I need to revert any change I have made to a class.
One of the most time consuming tasks is fixing a class after I close and reopen it because I forget to [right-click > save > save]. In fact, I frequently make two source commits because I have forgotten to save the class and I don't realize until after I have made the first commit.
If not exposed through the options dialog, can we at least get a new LabVIEW.ini key?
autosaveClass=True
OR
saveClassOnChange=True
