I'd like to see added to LabVIEW a 'Retain String Formatting' option for the concatenation operator. This would cause string formatting (the stuff you set with the CTRL-0 shortcut) to be preserved when concatenated. See the example below. This could be added to the right-click properties of the concatenation operator "Preserve String Formatting". An alternate symbol for concatentation would need to be provided so that you could visually tell that this option was enabled when looking at the concatenation operator on the block diagram. Maybe the NBC peacock sitting on top of it?
Sometimes setting string formatting attributes programmatically is a lot of work, and inappropriate to the application; simply not changing/removing the attributes would be sufficient... Note that the string formatting attributes are preserved across a cut-and-paste - if you copy the contents of a formatted string and paste it into another string, the attributes are retained. I find the current behavior of the concatenation operator (NOT retaining string attributes) to be at odds and inconsistent with LabVIEW. After all, it is a GRAPHICAL programming environment, is it not?
If I remember correctly, you also lose string formatting attributes when changing a string constant to a control or indicator - perhaps that also could use some thought...
