| User | Kudos |
| 11 | |
| 10 | |
| 10 | |
| 5 | |
| 4 |
When using the LabVIEW Internet Toolkit FTP library to transfer large files, there is no way to determine the progress.
I propose a notifier be added to the FTP Registry object data. This notifier would be updated by the low level TCP Read Stream and TCP Write Stream vis and monitored by a UI to display progress of the transfer.
See this NI Forum post...
http://forums.ni.com/ni/board/message?board.id=170&message.id=470946
