JDinkins
Add "Change all to Read/Write" to bundle/unbundle functions
Status: Completed
Available in LabVIEW NXG 1.0. You can change all to read/write on Cluster Property Nodes.
T
This idea could be applied to the bundle/unbundle primitives as well. Wiring may be an issue though (may produce broken wires).
This idea would be moot if the cluster functions were redrawn like property object functions (even better idea...).
-Jerry
19 Comments
JDinkins
Hrm, my post is incomplete?
here is the picture, anyways
Mr.Mike
NI Employee (retired)
I'm not a fan of this idea.  First off Bundle requires two wires of the type you're bundling and Unbundle only requires one.  It's not clear where that extra wire is going to come from / go to.  Also, anything connected will break.  It seems to me that Change All To Read belongs with property nodes because there's also the option to change an individual to read, and change all is an extension of changing one.
It doesn't seem to me that you'll often need to change from reading many items in a bundled type to writing.
-- Mike
JDinkins
Two options:
1. Instead of "Change all to Read", offer "Replace with bundle/unbundle"
2. Offer an object like property nodes, but for clusters. (<- this would be awesome)
I say this is a productivity issue because it's time consuming when placing new bundle/unbundle by names with large clusters (many types of non-uniform data). Most of the time, I prefer to copy an existing bundle/unbundle by name to avoid re-selecting the necessary elements.
elset191
Active Participant
 Property Node Style Bundle and Unbundle Element
Tim Elsey
Certified LabVIEW Architect
X.
Trusted Enthusiast
Trusted Enthusiast
To Mr. Mike: Here is an instance where the original suggestion would help.
ScreenHunter_004.jpg==> Right-Click>>Replace by "Bundle By Name"===>ScreenHunter_005.jpg
As you can see, you don't (always) need to worry about what to do with the source wire for the cluster type.
Second, the current replacement is rather stupid. It takes the "first" cluster element and replicate it. I am confident that this is the "intended" behavior (in the sense that this is how it has been programmed).
I don't think I am the only one that this is not the "expected" behavior.
Kudo from me.
Darren
Proven Zealot
Status changed to: Declined
X.
Trusted Enthusiast
Trusted Enthusiast
Declined is a shame. This is a good idea and should have got more exposure.
Darren
Proven Zealot
Status changed to: In Development
Darren
Proven Zealot
My mistake, this idea is actually In Development.
elset191
Active Participant
What a rollercoaster this is
Tim Elsey
