6 | |
6 | |
3 | |
2 | |
2 |
T
This idea could be applied to the bundle/unbundle primitives as well. Wiring may be an issue though (may produce broken wires).
This idea would be moot if the cluster functions were redrawn like property object functions (even better idea...).
-Jerry
Available in LabVIEW NXG 1.0. You can change all to read/write on Cluster Property Nodes.
