6 | |
2 | |
2 | |
2 | |
1 |
I would love to be able to right click on a local or a global variable on the BD and select "add anchors" to cause the object to change into one that looked like a value property node, with standard error in/out connections. The resulting object would simply pass error in to error out, but would delay execution until error in was available thereby allowing me to synchronously determine when the value would be evaluated, and eliminating the race conditions associated with local and global variables.
Aren't we supposed to be race-neutral anyway?
