LabVIEW has a feature that allow to quickly navigate from one occurence to another in the search result window (see image below).
I propose to add the same functionality to the error window (see below).
PJM
vipm.io | jki.net
+1. FWIW, I recently, unknowingly created a duplicate idea: Keyboard shortcut to navigate to the next edit-time error (broken run arrow reason)
