LabVIEW provides 6 VIs to allow reading and writing image files - each one pertains only to a specific format (bmp, jpg, png). We should add VIs which figure out which image format is given, and uses the correct image VI automatically in the case of reading. In the case of writing, the format is determined by the extension of the provided file name. I created a read and a write VI which does this here:
https://decibel.ni.com/content/docs/DOC-12141
I feel that this should be included in the image palette:
