3 | |
3 | |
2 | |
2 | |
1 |
The Probe Watch Window is a great addition to LabVIEW 2009 and I like that I have one centralized location to control all my probes.
What I don't like is that every newly created probe is embedded in the Probe Watch Window. There are various use cases where this is not desirable (see this discussion on LAVA for more info about it).
In the situation where you need the probe to be floating; instead of doing the following (for creating a new probe):
You have to do the following (for every single new probe):
Basically this take twice as much effort as before.
I think that we need an ini setting (or a button in the probe watch window) to automatically float probes upon creation.
