NIExpert
Add support for Absolute Paths to LabVIEW Projects
Status: New
It would be great if one could mark certain files as having an absolute path so that it is easier to move projects that use a common resource around in a multi developer/station environment.
A project might for example require a shared library or file that is installed by another application into c:\XXXX
Currently, all developers must place their project at the same relative folder depth to the shared resource to avoid linking issues.  e.g If Developer A uses c:\Users\Dev A\Project\  then Developer B would need to use  c:\Users\Dev B\Project\..   The project would complain about not finding the shared resource if Dev B was to use  c:\Users\Dev B\Repos\Project instead for example.
Marking the shared files as having an absolute path would resolve this
3 Comments
fefepeto_kb
Absolute paths would definitely not solve the problem as you presented. Absolute path means that there is no symbolic content, or any other resolvable component. With your example:
If  Developer A fixes the path to c:\Users\Dev A\Project\, then LabVIEW would have to search for this exact path even on the computer on Developer B's machine.
I know it's not perfect, and indeed we moved away from this solution to use relative paths everywhere, even though it meant restructuring our code, but VI Search path configuration can help with your use-case. Each developer could configure a list with priorities where to search for the files not inside the project: Adding a Directory to VI Search Path - NI.
NIExpert
fefepeto_kb  That is exactly the desired behavior and is supported by TestStand.
 For certain things you may want to ALWAYS link to a fixed path (c:\Users\Dev A\Project\ in your example).   This is especially the case where you are dynamically linking to 3rd party files that are ALWAYS expected to be in a fixed location.     Allowing "Absolute" paths would ensure that all developers and applications could resolve the path
fefepeto_kb
What I meant, is that the Dev B might not even have read access to Dev A's files. If thigs like that are expected, then the OS's ability to resolve symbolic paths like C:\Users\<username> folder are coming in handy. But in this case, all the files must be in place for all the users.
Having absolute paths will not translate well for cross platform applications, and also result in potential issues for the deployment. That's why, even when the relative paths don't make sense, the symbolic paths are used.
