13 | |
7 | |
3 | |
3 | |
3 |
It would be great if Package builds also supported these two arguments as is supported by normal installers Advanced Page (Installer Properties Dialog Box) - NI
The value in this, is that you could then store your package feed in a directory that is relative to the package and automate installing the package and adding the feed to NIPM.
Currently, as per NI support, there is NO way to do that.
