| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
For string controls and indicators please add a vertical alignment option. We have applications where we will programmatically change the font size, which requires a string control/indicator to be sized for the largest option. Since there isn't a vertical alignment option, the string is always aligned to the top and it can make the front panel layout look strange.
Other applications have long strings that may be a single line or may be a variable number of multiple lines, but we'd like to be able to center the text vertically. Again, this requires the control/indicator to be sized for the largest option, but all the text is always vertically aligned to the top of the front panel object.
