Usally we can add a event case by right clicking the event structure and adding it.
Its seems to be little time consuming if we need more cases. It would be better if we can add
all cases on single go.
So editor need to be modified such that we can select objects and events for each case.
Duplicate of http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Add-event-case-to-event-dialog/idi-p/970140
