Yamaeda
Adding several controls to connector pane at once
Status: Declined
Simple suggestion: Let us select several controls at once and drag'n'drop them onto the connector pane.
Let's for example say you're making some activeX wrappers and use the quick drops excellent "create all terminals" (or what it's called, ctrl+d, although the automatic placing needs some polish). Now you've got e.g. 3 controls and 3 indicators.
Now i want to select all control and drag'n'drop them to the connector pane so they fill slot 1-3 from where i drop them, and then i'll do the same with the indicators.
It'd also be grand if some logic would recognize error clusters and place them in the bottom corners.
/Y
Qestit Systems
Certified-LabVIEW-Developer
3 Comments
tst
Knight of NI Knight of NI
Knight of NI
That seems like a pretty specific use case to me. I would suggest simply creating another QDKS to do this or automating the creation of the wrappers, similar to what's shown in this thread - http://forums.ni.com/t5/LabVIEW/How-can-I-develop-a-ring-control-with-sub-menus/m-p/1795042#M619959
___________________
Try to take over the world!
Yamaeda
Proven Zealot
My explanation is very specific, but the ability to add/place several controls at once on the connector pane is a general idea. 🙂
/Y
Qestit Systems
Darren
Proven Zealot
Status changed to: Declined
