| User | Kudos |
| 10 | |
| 6 | |
| 5 | |
| 3 | |
| 2 |
Current Situation
The current commenting practice in the BD is to place free floating comment number labels and write the comment in a text field as in the example below.
Disadvantages
- comment number labels do to stick to the code block. if the code number block is moved the comment has to be moved as well.
- no link between number and comment text block
This unsophisticated way of commenting LabView code lead to the lack of comments in general. Usually a new programmer can understand what happens, but not why a function is implemented like this.
Proposal
LabView provides the Advanced Code Commenting Functions.
The comment block is more then just a text block. Basically it has a comment ID, the comment itself and a comment category.
By the context menu the following functions are provide:
Adding Comments
Adding a comment in the comment block incorporates two steps (after selecting Add Comment from the context menu):
1. Sticking the automatically generated comment ID to a particular code block just by selecting the item the comment belongs to.
This could be any type of code: wires, SubVIs, the whole Case, a particular Case, Sequences....
2. Writing the comment
If the mouse pointer is set over a comment ID the comment is shown like a tool tip and disappears as soon as the mouse is moved away.
Advantages
