I think there should be a way to have a network stream endpoint creator continuously wait for a connection. The problem with that is there's no good way to stop that "wait forever". I propose we create the network stream in two parts. The first one just creates a handle that can be closed later. The second one does the actual waiting like the normal create endpoint.
Declined for reasons listed here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Advanced-quot-Create-Network-Stream-Endpoint-quot-shou...
