8 | |
6 | |
4 | |
3 | |
2 |
At present you can only select controls/indicators from a common tab. This proves to be a pain when trying to align items throuch the tab container. ie you have 3 identical test panels mounted in a tab container and you want to align them all. this can be quite pain staking and time consuming.
Please can you have a look in to this so I can align or format C or I within different tabs of a common tab container
Andy Glass
