When I'm browsing Properties and Methods, the single most important tool is Context Help. However, if I open up a context menu to browse through the Properties or Methods, then hit CTRL+H, Context Help will not pop up! I must clear out the context menu I'm browsing by clicking elsewhere on the diagram, open up Context Help, then re-open the Property/Method list. I'd like CTRL+H to work when those context menus are active.
