Not available in LV 2103.
Why?
Case study:
I may not have a local variable, a PN or a wire for the type of constant I need in a specific portion of my diagram.
Therefore, since I cannot SEARCH for either a LV or a PN for fear of not being able to easily come back to that part ..., I need to be resourceful.
A simple solution (provided I know where to find it on the FP) would be to go to the FP, select the appropriate control and choose "Create Constant" in order to then be able to drop it onto the diagram (WHERE I want, not randomly, because that would kill the purpose of this suggestion).
Now I know that LV is schizophrenic and you can not let it understand that the FP and BD are basically one and the same thing, but still, I musn't be the only one to bang my head against that infrangible wall!
EDIT: of course, you can COPY the control and PASTE it on the diagram. I am talking about consistency in the Ctrl-Right contextual menu behavior throughout the IDE.
