13 | |
11 | |
3 | |
3 | |
3 |
At the moment you can Register for Events using a Cluster of Refnums.
But you cannot Destroy User Events or Unregister for Events in this way.
This approach allows for you to scale your application without the need to change the code that handles Registering Events.
It would be very convenient to be able to close references in this way (using a Cluster of Refnums) too, as per my illustration below:
