3 | |
3 | |
2 | |
2 | |
2 |
These two structures can be replaced with each other, but not with a case structure. I can't count how many times I've drafted some code, then want to reuse some or all of the cases selectably at runtime. Changing to a Conditional Disable Structure is halfway there, but then I'd still need to have a project file to define and edit custom symbols, which I often don't.
