6 | |
6 | |
3 | |
2 | |
2 |
When you connect the error wire to a case structure selector, you get two cases for error and no error. I think you should be able to add in cases for specific error numbers so you can handle specific errors differently. You could do this currently, but you would have to unbundle the error and use the error code.
Available in LabVIEW 2019 and later. You can now specify one or more error frames on an Error case structure, and use numeric ranges in those frames for ranges of error code values in the error cluster.
