5 | |
2 | |
2 | |
1 | |
1 |
Sometimes, it would be handier to have the timeout terminal move along left side of the Event Structure, not tied to the top-left corner. Also, when you wire internally to this terminal, the wire is obscured by the top of the Event Structure border (where did that mysterious wire come from?? Double-click to highlight... oh, the timeout terminal)
For completeness, I think this idea should also be applied to the Count Terminal of For Loops. (You might consider it a companion - or the opposite! - of the Option to Show/Hide the Iteration and Count Terminals of For Loop).
Oh, and certainly, if this terminal can move, make the structure corners non-magnetic!!!
