6 | |
6 | |
3 | |
2 | |
2 |
When setting the option "Separate compiled code from source file" will make the .vi-file NOT to contain executable code.
The forum filter accepts .vi files to attach to posts. But if selecting VIs with this option set, the posting is declined with the remark that the file type is invalid.
I recommend updating the attachment filter to accept VI files with compiled code removed.
Norbert
