11 | |
3 | |
2 | |
2 | |
2 |
As per LabVIEW Help (pointed out by Jim_S - cheers) you cannot add an X-Control or X-Control Reference as a Class Data Member.
Well I found out (the hard way) that technically you can in dev time but at run time your build will be broken.
E.g. I would like the ability to add an X-Control Reference as a Data Member of a Class so that I can encapsulate display state changes whilst enjoying the benefits of Classes etc...
Cheers
-JG
