13 | |
7 | |
3 | |
3 | |
3 |
This is related to this issue, https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Run-Code-Cleanup-profile-Nattify-VI-on-Save/idi-p/429...
and is a more general request.
Have the ability to run custom scripting code on a save event.
What problem does it solve?
For me personally, I am working on an autoformatter. It would be nice to run that everytime something is saved. Right now I have to monitor the source folder from outside LabVIEW (using Python) and then use G-CLI to run my formatted. I'm sure there are probably other ways to do it and an onSave hook seems like the best choice.
I'm sure there are plenty of other use cases. Perhaps some kind of linting or enforcing some sort of style guide. ie if you save a VI without a description, it won't let you unless you enter a description. Perhaps even every time you save a file, run some unit tests?
Ideal Solution
Ideally the scripting code would have access to the reference of the thing being saved. The easiest thing to envision is a VI, but why not also classes, libraries, the project itself? Maybe also some indication of what triggered the save. Was it a saveall, a save all this library, etc. Maybe if it is a saveall, you get a list of all the things being saved, before anything happens?
The IDE would then wait to continue until the scripting code completes, maybe even failing to save on an error or a boolean - not sure if that is the best behaviour as in a bug in your scripting code could cause you not to be able to save - so maybe some way to override the hook?
Maybe include a way to autogenerate a VI with the correct connector pane.
Maybe it makes sense to generalize this to add more hooks into LabVIEW? Perhaps a call to update the project provider to something more usable/less user-hostile?
