At present the only way to update the icon for a new class member is to go to the class properties and copy it's icon and then paste it in the new VI's icon editor. Yes, it is possible from the class properties to assign the icon to ALL class members but that is overkill when simply adding a few new members. In addition, it causes havoc with source code control since every class member has now been modified. It would be convenient if the icon editor allowed class member to simply inherit the class icon template directly. This would save the copy/paste action as well as thrashing of the source code control system.
