13 | |
11 | |
3 | |
3 | |
3 |
currently the property node only accepts a single reference.
For setting a property or calling a method on an array of references,
it is currently required to surround the node with a for loop.
It would be much easier if the array of references could be directly conected to the node,
especially for situations like enabling, hiding, ... a list of controls
