jpa_
Allow breaking up long wires with labels in each end
Status: New
In electrical schematics it is common to break up long wires with a label in each end. I wish this feature was available also in LabView.
The wire should still work in a data-flow way, unlike local variables. It should also be possible to have many connections to the same wire.
22 Comments
art_
I'll chime in on this from the perspective of a LV FPGA user doing DSP. Virtual wires would be a godsend to me. FPGA vi's have a lot of ancillary signals flying around like enables, resets, clocks, triggers, etc. that can rapidly obscure the signal flow that matters and turn your code into a rats nest. And I know it's heresy to say it but bundling things into subvi's and clusters to clean up a block diagram only hides the mess. You end up bundling disparate functions into a subvi and clustering signals that have nothing to do with each other. It makes for very pretty but entirely unreusable code. block-to-block handshaking should understandably be wired directly. But things that originate from far off and branch in a million directions (like resets) badly need this. Virtual wires and good labeling would make things so much easier. Sure It can be abused. But anything can be abused.
bkardon
YES! Yes. And yes. And when you hover over either of the labels, it would display a temporary "as the crow flies" dotted line connecting the two labels, and if you clicked on a label, it would jump your view over to the other label.
