8 | |
6 | |
4 | |
3 | |
2 |
Browsing through menus to replace a numeric conversion node is tedious. How about allowing the selector tool to select from a pull-down menu, just like it does from an unbundle by name node?
Existing unbundle node behavior is shown at left. Desired numeric conversion node behavior is to the right.
Available in LabVIEW 2019 and later. Right-click on one or more conversion bullets and select a new bullet type from the 'Replace Conversion' submenu.
