 fabric
			 on
		04-10-2013
		10:11 PM
			9 Comments (9 New)
			fabric
			 on
		04-10-2013
		10:11 PM
			9 Comments (9 New)
		In LabVIEW, data types generally propagate downstream. If you wire a cluster output into an "unbundle" node then the IDE lends a hand by resizing the unbundle node automatically. Nice.
I would like to see the same behaviour applied to the "bundle" node. In this case the type information needs to travel upstream. Yes, backwards!
Excuse the overly simplistic example... Yes, I know we could just connect the bundle node's middle terminal in this case, but it illustrates the concept.
A more realistic use case would be nested clusters or nested private data in a class. In this case propagating the type upstream could be quite handy when bundling various sub-clusters:
Note: There are not many situations where the IDE will allow a data type to propagate upstream, but there is already some precedent for this: In certain situations the "Variant to Data" function will automatically assume the type of the wire connected to its output.
