One of the (frankly many) ways that the Labview Compare Heirachy could be improved is to add support for comparing actual projects.
For instance, I might want to see at a glance what is different between two build specs, or whatever.
At the moment, this leaves me reaching for BeyondCompare (other diff tools are available
