6 | |
6 | |
3 | |
2 | |
2 |
The title says it all. Currently this is not possible.
And yeah sure there are workarounds, like using a Waveform Graph. But they aren't good enough. I can't use waveform graphs, because I want to use STACKED PLOTS, which isn't possible (see here) in Waveform Graphs. So please give me one or the other: Stacked Plots in waveform graphs or Cursors in Waveform Charts. Right now, I need both.
