CVI allows for color modification of the sweep line in a sweep chart (ATTR_SWEEP_LINE_COLOR), but LabVIEW does not allow any modification of the sweep line.
It would be nice if the developer could change sweep line width and color to make the sweep chart fit better visually in a customer-facing UI.
