13 | |
11 | |
3 | |
3 | |
3 |
What I find annoying, cumbersome and time consuming is when I want to take some code and "demote" it to a sub VI. If there are any top-lelvel (that is, user interface) front panel controls and indicators it becomes a nightmare. I know that references to the front panel controls and indicators can be used, but it's so much more work. So often, something which has grown that should be made into a sub VI remains at the top level.
Maybe I'm missing something here and there is some technical or useabiity issue.
Fundamentally what it is, is doing what passing a top level VI control/indicator reference to a sub VI and using the reference for control does, but behind the scenes.
