13 | |
8 | |
3 | |
3 | |
3 |
Currently in LabVIEW you can have a top-level palette (Programming, Measurement I/O, etc) automatically populate based on .mnu files existing in the folder structure at <LabVIEW>\menus\Categories\. However you cannot do this with the sub-palettes such as Arrays, File I/O etc.
I propose to allow auto-populating palettes for all LabVIEW palettes so developers can place their own palette within the appropriate LabVIEW palette for their functions. One example is OpenG and MGI each have a palette of Array functions. They are currently placed in a top-level OpenG\Array or MGI\Array location. If we could sync these folders, we could place each of the array palettes under the Programming\Array palettes:
Simply by dropping their corresponding mnu files here:
Thoughts? Discussion on LAVA that spawned this idea is here.
