8 | |
6 | |
4 | |
3 | |
2 |
There's a useful shortcut (sometimes refered to as the "switcheroo" tool) which allows you to swap the inputs on primitives with two inputs if you Ctrl+Click the primitive.
It would be useful if this shortcut also worked on the inputs of the Select primitive. Ctrl+clicking one of the inputs would swap them:
Actually, what would be better (and a more general solution) was if this idea was implemented, but with 2 kudos that seems unlikely. 😉
