Every time I need to open up several VI's at the same time, my Windows Taskbar becomes full of open windows and it gets hard to wade through everything. Part of the reason for this is that every time a VI is opened, two windows have to be opened to view the block diagram (both the front panel and the block diagram). I would like to see a fix that allows me to just have several block diagrams open at one time without their front panels, making it easier to deal with the numerous open windows I get sometimes.
