4 | |
4 | |
3 | |
3 | |
3 |
The current implementation for remote debugging needs two ports to be opened on a stand-alone firewall in between.
This dynamic port cannot be pre-configured on the stand-alone firewall except by opening up the whole port rang above 1024.
The latter is something no IT person with any sense of security will do !
So we need to be able to pre-configure a certain port for the target application, so that we can open a dedicated port for this connection on the firewall as well.
Otherwise this whole remote debugging feature is useless to us.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
