| User | Kudos |
| 11 | |
| 11 | |
| 7 | |
| 5 | |
| 5 |
Flattened String To Variant is so close to letting us define the layout of arbitrary external data. However, labview's insistence on all strings and arrays being prepended with their lengths in the data string means when working with binary data from non-labview sources, the array or string lengths might have to be calculated or are somewhere not immediately adjacent to the data. I understand it's far too late to modify the base unflatten from string or read from file as requested in this idea, but this feature would be incredibly useful for reading binary data directly into clusters without requiring either multiple copies of incredibly large (100,000+) arrays floating around, or incredibly tedious and complex sequences of Read from Binary File nodes.
