550nm
Allow vertical Case and Event selector lists.
Status: New
Once in a while I encounter a case or event list that forces me to grow the structure
- in order to keep the list readable:
It would be nice if the item-list would automatically "wrap" instead.
4 Comments
Mads
Active Participant
In my mind the real idea here (kudos given) is to have the ability to manually expand the item-list box vertically, and *then* get the items to wrap.
I would not want the item list to always and automatically expand like this (although that could be an option one could turn on/off globally and/or on the individual case).
X.
Trusted Enthusiast
Trusted Enthusiast
I was about to say that Next Gen Preview has something that would address this (at the expense of a lot of annoyance, in my opinion): a list of all cases on a side panel (see below).
But in fact it shows the same problem:
The panel cannot be resized (only partly collapsed) and therefore you can't see the full list of cases in the last line...
Sigh.
xl600
Active Participant
I wish it could kudo this multiple times!  I use enumerated extensively for state machines and other controls, but the horizontal only list forces me to have to duplicate cases just to see the list in man cases.
Petru_Tarabuta
Active Participant
+1 Kudos.
Like xl600, I too sometimes create duplicate cases in my case structure to have full visibility of what enum value selects each case (at the cost of duplicate code / two points of change instead of one).
The best implementation seems to be Mads's idea "to have the ability to manually expand the item-list box vertically, and *then* get the items to wrap.", not to have the item list box expand automatically as it may take too much space for cases with dozens of selector values.
