One of my pet peeves when using the Unbundle or Bundle by Name occurs when I remove or add an item from a cluster and LabVIEW attempts to find the item with a similiar name. The behavior should always break when the specific item in the Unbundle/Bundle by name is removed.
More often than not LabVIEW picks the wrong thing and introduces programming bugs.
