13 | |
11 | |
3 | |
3 | |
3 |
This is a very small suggestion, and hopefully easy to implement. When wires cross, very often one of the wires involved is an Error wire, and as it is usually wired last, it sits on top of all the other wires. All I'm asking is that Error wires are always placed underneath all other wires when they are created. To my mind, this improves the readability of the diagram.
What would help further is if Error wires were "faded", as if they were 50% transparent. You do need to be able to see them, but not such that they stand out. But I'm much less certain that such a change could happen. The khaki color is an improvement on the old pink though, that's for sure!
