alternative flavor to the current text type control/indicator...
You can build an XControl to do this if you commonly need it. I believe one already exists:
https://forums.ni.com/t5/Example-Programs/XControl-Clock/ta-p/3534619
We will leave this idea open to see the kudos it gains, but my expectation is that it is not a common enough request to warrant adding to the standard LabVIEW controls.
