SteveP
Annotation Font and Style property
Status: Declined
It would be useful to be able to change the Annotation Font Size and Style
5 Comments
AristosQueue (NI)
NI Employee (retired)
Are you referring to "graph annotation names"? That's the only reference to "annotation" that I can find in the LV help files.
SteveP
Active Participant
The Graph's Annotation Name's font size cannot be adjusted right nowR-Click > Data Operations > Create AnnotationThen R-Click on the annotation point and choose attributesThere is no setting for Name > Font...
I would like to make it larger so users can more easily read it.
See :
http://forums.ni.com/ni/board/message?board.id=170&message.id=226681&requireLogin=False
Mads
Active Participant
I was thinking about posting a similar thing - however I'm thinking that the graph annotations could easilby be expanded to also be a general "draw on the graph"-tool. Instead of just having text with arrows I would like to be able to draw circles and rectanges - and put comments either within them or have the already existing text with arrow point to those. We often have users that want to comment on trends and then print them as reports...but currently they have to move the data from the LV apps to e.g. Excel or Word and then add the graphical elements and comments. If annotations were just a little bit more than just the text with arrows - we could skip having to make a drawing tool for graphs:-)
SteveP
Active Participant
I've used the 3rd party TeeChart graphing component at http://www.steema.com/ with Delphi for other applications.  It is capable of doing what you want and much more with plenty of control of many properties including event firing.  There is an ActiveX version that maybe could be integrated into LabVIEW.
Darren
Proven Zealot
Status changed to: Declined
